That one would be barely usable (about 10dB attenuation only)bruce0 said:These are the little inductors.
The metal case is 55mH, 55 Ohms DCR
This one not. Only 6dB attenuation in the best case.The plastic case is 118mH, 143 Ohms DCR
I got several lovely little shielded inductors from Nebraska Surplus
Some have too high DCR; in your application, you're looking at DCR >40 ohms.
Sorry, typo; I meant DCR <40ohms.earthsled said:Some have too high DCR; in your application, you're looking at DCR >40 ohms.
I measured the original MD421 inductors at L1 = 31.8R and L2 = 45.2R
Mouser's best 82mH choke is listed as having a DCR of 71R, so probably too far out of spec., I would imagine.
That's very likely. Inductors have losses that are equivalent to an additional load.bruce0 said:The MD421 specs say 200 ohm output impedance at 1000 Hz, so rolloff at 863 ish using the calculations matches the graph well. Newest Sennheiser product sheet shows attenuation all the way up to 10K, maybe because of the load this puts on the mic?
You are absolutely right, this is a concern. For a condenser mic (or any mic that relies on built-in amplification), a 2nd-order filter (C-L-C) may be preferrable because its input impedance is higher. The difficulty is passing phantom power, so the filter becomes something like 3 caps (one big), 3 resistors, one inductor. Obviously, it's much easier to do that in the head amp.What happens when a big LF frequency wind flutter goes out of the transformer-less buffer on the mic and into what looks like 100ohms load presented by this filter, is there a concern that that overloading the mic might cause distortion in the high frequency signal at that moment?
If the designer has done his homework, the reactance of the caps will act at a very low frequency. Impedance switches or pots are usually before the caps, so it won't interact with them.tv said:With transformerless pres there will usually be additional capacitance (input caps), adding an additional reactance into the passive circuit. The preamps' input impedance may be seen as a series resistance (~~) to caps' reactance and may be sufficiently high to be seen as unimportant - but what happens if the micpre has "impedance tweak" pot going sufficiently low (and not necessarily in front of the caps, making this essentially a L-C-R tank, and the pre of course "listening" what happens at the "R" node). This is likely going to skew the response in lower mids (from top of my head). Perhaps even more than pres with transformer input?
What construction are the inductors in the Sennheiser?
It will however interact with a passive HPF. In the case of a simple C-R filter, it will shift the frequency upwards. In the case of an CLR filter, it will reduce the Q, making the filter less steep but over a larger BW.
As I surmised, they had to use a core of about the same size as they would for a mic input xfmr.earthsled said:Upon closer inspection, the inductors look more like a transformer - sharing the same core. Unfortunately, it doesn't look like an off-the-shelf type of component.
It can be done, however it's gonna be a compromise. As microphones' actual impedance vary from 100 to 500 ohms, you have to shoot in the middle, so let's use the nminal 200 ohms value.This sounds like a design I'd like to try - a filter that could accommodate both passive and active mics, located in the preamp rather than the mic itself... ...If the filter is kept passive, could it be designed to accommodate a wide variety of mic outputs and preamp inputs while still doing an adequate job of reducing LF rumble?For a condenser mic (or any mic that relies on built-in amplification), a 2nd-order filter (C-L-C) may be preferrable because its input impedance is higher. The difficulty is passing phantom power, so the filter becomes something like 3 caps (one big), 3 resistors, one inductor. Obviously, it's much easier to do that in the head amp.
I also played with the sim wrt to my previous remark and your statement is true when you deal with a "well-behaved" micpre.abbey road d enfer said:...
The response varies significantly in regard to the actual mic impedance, not so much in regard to load impedance
I've spent some time working on it when I found I had a ribbon mic acting funny.tv said:Btw. do you have any "good enough for most cases" simulation of a "mic source"?
I used an ordinary R at 200 Ohms as a mic "sim", but that's quite, well, naive.
Isn't it exactly what I wrote: "those with transformers are accurately modelled by a resistor and an inductor in series."tv said:I was hoping to find something simple to implement wrt the dynamic mic "sim", like an ac current source driving the (mic coil) inductance followed by mic's .... 200 Ohm resistor, haha. Iow, something that "just works", similar to some hacks that represent the guitar/bass pickup.
Due to the rather large DC resistance, the slope will be a little less steep - about 10dB/oct instead of 12.earthsled said:Hi all,
I just wanted to know if this Tamura inductor (attached PDF) would fit the spec for Abbey's HPF circuit. It seems to have an acceptable DC resistance of 40R. Is 4mA okay for the DC current?
Turns ratio is irrelevant to this calculation; only the primary matters. A good start is L at 5H and DCr at 20 ohms.earthsled said:I wasn't quite sure what parameters to set for XFMR1. The software allows for turns ratio, DC resistance for primary and secondary, and inductance for the primary. Currently, I have these parameters at the default values.
