petermontg
Plus they are log pots. You can build the resistor chain the same. Check back through the thread for wiring.
Harpo said:These -different project- posts from you might be related to your problem ...
frazzman said:Just have an issue with a the Calrec mini PSU board. Basically I etched one to use for another projector (2x net EQ). Anyway, I used alternate regulators to get a 18v supply. The only issue is on my 30VA toroid, the secondaries seem to be a bit hotter than normal. So I end up with about -/+ 20V rather than 18v.With your 2x25VAC secondaries unloaded and kept a secret mains transformer in front you operated the fixed voltage regulators above their abs.max. 35VDC input voltage (and as well maybe the storage caps), so these might be damaged and maybe still are with your now 2x18VAC transformer in front. If you once have connected this maybe faulty supply to your NetEq pcbs (from Gustav or self etched as well?), not all of the populated NE5532s might have survived. Just an idea.frazzman said:Nescafe said:20V at unload condition? That is OK in most cases, try that with some load and measure again, BTW if You use NE5532 op amp that's OK (+/-22V Max).
Thanks for the quick reply....yes at unload - actually closer to 21v
It turns out I'm an idiot and I accidentally ordered a 30va 2x25 instead of 2x18...
Will 7818 and 7918 regs play nice with this extra voltage ?
The net eq is jam packed with ne5532s so I'm glad to hear they will cope with the surplus voltage...
petermontg said:Plus they are log pots. You can build the resistor chain the same. Check back through the thread for wiring.
ruairioflaherty said:frazzman said:Good advice, thank you....
I'm regards to a signal probe - perhaps something like this :
http://web.archive.org/web/20050310014839/http://www.diyfactory.com/data/mbsignaltracing.htm
Mnats had a link on his site to this page and I made one of these probes but never had a need for it... (Until now)
I don't think you need to go that far. Without a scope what you are looking to do is measure just parts of the circuit through RMA, first input stage, then after first eq bands, then after HPF, then after output stage. It should help you find the area of the circuit that's oscillating.
To do that you'll need to go balanced out of and unbalanced in to your RMA. It's crude but lacking a scope it could help narrow down the trouble spot.
biigniick said:try replacing U5... swap with U6 maybe? see if the problem migrates to output stage only. that would indicate a bad IC, i would think,...
- nick
ruairioflaherty said:0.2% distortion in bypass is awfully high, I need to look at the schematic again but from memory it's a full relay bypass.
What does your analyzer rig measure from output to input? Within nothing in line.
I didn't mean for you to probe with tone and ears, use your probes to measure the distortion with your analyzer, again isolating each stage.
I would never buy ICs from ebay, too many fakes these days! Hoping that maybe that is part of your issue.
druu said:ruairioflaherty said:0.2% distortion in bypass is awfully high, I need to look at the schematic again but from memory it's a full relay bypass.
The unit uses relay to bypass but will only pass audio when powered on. So it's not true relay bypass by the schem.
biigniick said:The relay bypass does not bypass the input or output stages. In bypass signal passes through the input stage all the way to C7 and goes directly to C30 in output stage. Still lots of parts in the signal path even in bypass.
- nick
frazzman said:druu said:ruairioflaherty said:0.2% distortion in bypass is awfully high, I need to look at the schematic again but from memory it's a full relay bypass.
Thanks man, you're right... My d-la2a is relay bypass too but passes audio with no power.
petermontg said:Got some spare time to take another look at mine.
Power issue is solved no more 10r smoking and everything lights up, relays click etc etc 8)
Next step is some test.
druu said:petermontg said:Got some spare time to take another look at mine.
Nice. What was it? Swapped +/-18v wires from PSU?
petermontg said:A couple of things presented themselves in the right channel.
Mostly freq selection switch with only the last 90 degress of selection working the rest of the switch is boosting the entire spectrum. Cap problem?
right HPF drops volume when engaged.
Not major problems but does anybody have any hints.
Best
Peter
