frazzman said:Gustav said:frazzman said:Hi guys,
Almost finished my build so close I can taste it!
Just finished wiring on my right channel. All checks out except for an issue on HF band. Shelf is fine but peak isn't working for boost or cut., just stays at 0 - freq plot is flat.
I'm using stepped switches as per Harpos spreadsheet.
This channel is built identically to my (working) left channel. Any ideas ? If shelf works, where should I focus for peak issue ? I'm reading the right resistance on at the pcb so I'm know switch is wired correctly.
Thanks a lot
Did you figure this out?
Gustav
Hey Gustav,
Yes I did, thank you mate. Wrong resistor value somewhere.
Everything is pretty much working except for one overall anomaly, affecting both channels - even in bypass.
I'm observing some noise/ripple in the higher frequencies...Very prevalent with a HF boost. The plots from RMAA explain all....
It's quite audible, even though the unit is very quiet and hum free with no audio passing. With audio present you can hear this 'ripple'.
Did you ground your pcbs ? I haven't done that and I am wondering if that's where my problem is?
Thanks a lot
Gustav said:frazzman said:Gustav said:frazzman said:Hi guys,
Thanks a lot
Gustav
Hey Gustav,
Thanks a lot
I had ripple on a band which turned out to contain a cold solder in one of the cold solder (I realised at some point, the ripple only occurred when I had it over a specific frequency and checked the spots). That may be worth checking out!? Also, check for shorts/near shorts on the switch.
Remember, the shelf is separate from the bells, so you are switching to a totally different part of the circuit/different part of the switch between the two. If you see a problem in one and not the other,.
I am not sure what you mean about grounding the PCBs. I connected the ground points to chassis as marked in the schematic, of course, but maybe "grounding the PCBs" covers something I am not aware of.
Gustav
biigniick said:Frazzman,
It's hard to tell from the MP3 files, but it sounds like distortion of some kind. Maybe an impedance mismatch or level too hot on the record input? Does the problem go away if you patch the eq out (disconnect the eq in and out and plug the wires together to capture just the signal looping through the cable)?
- nick
ruairioflaherty said:Have you checked for oscillation with a scope and square wave combo?
What kind of THD figures are you getting in RMA for a loopback and for the unit?
Are you sure you are running the RMA sweeps at low enough levels to avoid clipping on output or input?
Exactly what I thought!ruairioflaherty said:If that's -1.5dBFS it seems awfully high, any small response deviation or gain will cause your RMA rig to clip. I'd be running that at at least -6dBFS, sure you'll have a 6dB higher noise floor but that's not a big deal IMO.
Yep, all those 100nf caps are ok. I tried dropping my input and output levels drastically but it didn't affect the oscillation/distortion. It was prevalent even with low levels.ruairioflaherty said:I would ignore the RMA suggested levels, that is sailing way to close to the wind for a device with any gain at any frequency. That said I don't think that's your issue.
Do you have any local access to a buddy with a scope? That's really the best tool to track down the issue as you can feed a square wave in and scope after the input stage, after the EQ bands, and again after the output stage.
It would probably also be a good idea to confirm that your PSU bypass caps on the NE5532 are all the right value, did you measure each one as it went in?
frazzman said:Yep, all those 100nf caps are ok. I tried dropping my input and output levels drastically but it didn't affect the oscillation/distortion. It was prevalent even with low levels.
I don't know anyone who has a scope but I'm going to try and find one!
Just a thought - in regards to r20 and r26, these have been omitted as per the guidelines in Barry's doc, I take it that they don't need to be jumpered right ?
ruairioflaherty said:frazzman said:Yep, all those 100nf caps are ok. I tried dropping my input and output levels drastically but it didn't affect the oscillation/distortion. It was prevalent even with low levels.
Cool. Good practice to run that at lower levels especially if you are looking at EQ band sweeps with gain.
It will make light work of this.
Just took a quick look and both should be omitted completely and not jumpered.
Are your inputs and outputs to your RMA rig balanced? If so perhaps you can make a cable to unbalance them one at a time by connecting pin 3 and ground. Then you might be able to inject a balanced signal and probe the circuit with an unbalanced alligator clip - at several points along the circuit to see where the oscillation is creeping in?
frazzman said:Just have an issue with a the Calrec mini PSU board. Basically I etched one to use for another projector (2x net EQ). Anyway, I used alternate regulators to get a 18v supply. The only issue is on my 30VA toroid, the secondaries seem to be a bit hotter than normal. So I end up with about -/+ 20V rather than 18v.
With your 2x25VAC secondaries unloaded and kept a secret mains transformer in front you operated the fixed voltage regulators above their abs.max. 35VDC input voltage (and as well maybe the storage caps), so these might be damaged and maybe still are with your now 2x18VAC transformer in front. If you once have connected this maybe faulty supply to your NetEq pcbs (from Gustav or self etched as well?), not all of the populated NE5532s might have survived. Just an idea.frazzman said:Nescafe said:20V at unload condition? That is OK in most cases, try that with some load and measure again, BTW if You use NE5532 op amp that's OK (+/-22V Max).
Thanks for the quick reply....yes at unload - actually closer to 21v
It turns out I'm an idiot and I accidentally ordered a 30va 2x25 instead of 2x18...
Will 7818 and 7918 regs play nice with this extra voltage ?
The net eq is jam packed with ne5532s so I'm glad to hear they will cope with the surplus voltage...
frazzman said:Good advice, thank you....
I'm regards to a signal probe - perhaps something like this :
http://web.archive.org/web/20050310014839/http://www.diyfactory.com/data/mbsignaltracing.htm
Mnats had a link on his site to this page and I made one of these probes but never had a need for it... (Until now)
biigniick said:my question is with the Q and frequency selectors. they are also center tapped linear 10k pots, but the calculator does not give a string of similar values like the level calculator.
