zamproject
- Joined
- May 11, 2010
- Messages
- 1,597
Hi all
Just fixing various issues on a elka rotary speaker cab
I get about everything going on and fix various minor fault, but I'm still puzzled with the reverb driver and the associated regulation that was initially faulty.
Very basic, audio supply +/-40v, no reg, just fullwave and caps
Then the separate pcb for reverb driver around an old TAA611 "power" IC regulated by a 11V zener via a 270ohm from the +40V rail.
Initially supply at this pcb measure dead, 500mV IIRC, I check the zener and obviously was short.
I change the zener, check the 5W resistor and voltage was very high, well over +/-5% and increasing, at about 12.8V at DMM after let say a minute, I cut the power.
I also measure the V+ rail and it goes around 45V in place of 40, I check primary and there is no option as it's an old 70' fixed 220 single primary (my wall is more around 235)
My quick math for the zener and 270ohm give a close to limit for dissipation at 40V and suspecting heat issue in the zener, so I decide to replace the 270 with a 330 (just what I have in stock @5W) and the voltage still go too high I think, at about 12.6V (loaded and unloaded...)
But I don't get why I'm so far from Zener voltage
I realize I don't use zener that often and probably miss thing about it ...
Best
Zam
Best
Zam
