Speaking of soldering irons - a few years ago I upgraded from an ok better-than-cheap iron to the cheapest JBC iron with an active tip. That was a real game changer for me.
Yup! Even lessI've heard they are good. Hakko FR301, uh? - Indeed, the US version is way cheaper - $ 280 vs. € 380.
But still: Around 300 bucks for a beginner's budget?! Hmm... is there a product in the 50 bucks range?!
Oh YES! Desoldering gun is important. Will add that to the list. Any good recommendations anyone? I am just using a cheap air pump/tip type, that get's stuck every once in a while - not convincing.
This is my desoldering gun: https://www.elmisrl.it/en/product/den-on-sc-7000z-desoldering-tool/Oh YES! Desoldering gun is important. Will add that to the list. Any good recommendations anyone? I am just using a cheap air pump/tip type, that get's stuck every once in a while - not convincing.
I used to use a desoldering pump like this for many years & even doing large console recaps. What I found was that most of the time it was ok, but if I was using it on old circuit boards like my MCI desk, the recoil would tear the pcb tracks up. Whilst the Hakko is no doubt expensive one has much more control when using it.Yup! Even less
https://www.aliexpress.com/item/1005005676816117.html
Been using one for years with good results. It can even suck the solder completly at first try.
Sure, no good for production work but for one-off, occasional builds? Sufficient enough.
No doubt it's not perfect. Not even great. Just a basic, cheap, a bit clumsy tool.I used to use a desoldering pump like this for many years & even doing large console recaps. What I found was that most of the time it was ok, but if I was using it on old circuit boards like my MCI desk, the recoil would tear the pcb tracks up. Whilst the Hakko is no doubt expensive one has much more control when using it.
Thank you for your appreciation and the suggestion to add REW best practise examples and using scopes. Although measuring all my build stages already, I would love to learn more in this regard as well - as I am sure there is way more to it than I know.@Roman Beilharz great thread. I would add getting familiar with REW which is free, and learn how to inject and probe signals using it, with or without an additional scope. Pocket scopes are also cheap these days, and it can be quite useful getting familiar with one. Using a scope should be quite intuitive and relatively easy for anyone doing any kind of audio related work.
Recoil is indeed a problem.What I found was that most of the time it was ok, but if I was using it on old circuit boards like my MCI desk, the recoil would tear the pcb tracks up.
One hint: To be able to mount the Manfrotto clamp on a mic stand, you will also need this spigot adapter:Great thread, not just for mic building of course. Didn't know about the Manfrotto clamp, thank you!
Thank you very much for your recommendations, that was exactly the kind of "bang for the buck" I was looking for. And didn't know about the reverse tweezers, makes a lot sense when thinking about it! Will add both to the primary list.Good pair of reverse tweezers are gold, as well as a Japanese SS-02 solder sucker. That thing is incredible. I've tried multiple desoldering stations, multiple solder suckers, solder wick, and nothing beats the SS-02.
SS-02: https://www.amazon.com/Engineer-SS-02-Solder-Sucker/dp/B002MJMXD4?th=1
Reverse Tweezer Set: https://www.amazon.com/Bundle-Soldering-Tweezers-45-Degree-90-Degree/dp/B073SJD7L5
Plenty of other useful bits and bobs i've acquired and use over the years. Love having an LCR and ESR meter, a good o-scope doesn't hurt (although rarely do i need to break it out), a cheap interface you're not afraid to blow up, a signal generator, and good tweezer or hook-style probes.
I've also been using this one for some time, the suction power is really good, but unfortunately the recoil is also quite strong.I've tried multiple desoldering stations, multiple solder suckers, solder wick, and nothing beats the SS-02.
+1, must have! You find the best ones in the medical field, unfortunately expensive and not isolated.Reverse Tweezer Set:
Honestly one of the better investments. It's simple really - with regular tweezers or pliers you have to tense your muscles to grip the item, which makes it inherently less steady. Letting the tweezers do the work for me has made me much more accurate.Thank you very much for your recommendations, that was exactly the kind of "bang for the buck" I was looking for. And didn't know about the reverse tweezers, makes a lot sense when thinking about it! Will add both to the primary list.
The foam inlays are nice. I designed and 3D printed a simple adjustable mic cradle that takes two 1/4in 6" long bolts and two matching wingnuts, that gives me more solidity and more adjustability.I've also been using this one for some time, the suction power is really good, but unfortunately the recoil is also quite strong.
My tip for safe and comfortable working with microphones are these foam inlays for microphones. The microphone always stays in the position you need, the foam literally sticks to the desk, nothing turns away, stable thing...simple but very effective. Mega bang for the buck![]()
