kato
[quote author="PRR"]> burn out transistors using a chunky radio shack soldering iron
That is VERY hard to do, with Silicon transistors and 60/40 solder. Silicon will survive and even work at solder temperatures.
[/quote]
Wow, really?!?
I guess I can stop using "burned out transistor" as the excuse for why my Tycobrahe Octavia clone doesn't work. All the symptoms point to a bad transistor - but perhaps I just wired it wrong.
Hey thanks for the pointers! Do you use rosin core solder?
Or some other kind of flux?
Thanks, Kato
[/quote]
Wow, really?!?
You should be able to get a good joint in 10 seconds start to finish. The iron must be not just clean but "wet" with solder: a dry tip does not get enough contact area to heat the joint quickly. Parts must be clean so you don't have to boil a lot of flux to break through tarnish. If you can get in and out in 10 seconds, tip-temp isn't very important.
For reference: my tip glows in the dark. Very faint red. This is too hot unless you have a lot of practice, and know when to get-off if the joint isn't taking solder real quick.
Thanks, Kato
