Behringer ADA-8000 owners: PLEASE READ!!!
I will change capacitor either way
If you know the supply current, you can estimate what the ripple voltage is expected to be and get an idea of whether the capacitors are drastically degraded or not. Or many multi-meters include a capacitance measurement capability, you can measure using that taking some care about other devices connected that might disrupt the measurement.
The formula is Vr=I/2pifC
From the schematic it appears that C=1000u, f=100Hz, and according to post #33 the current is around 0.760A.
Vr=0.760/2*3.14*100*0.001=1.2V
Actually there is a comment later which indicates that some transformer under discussion could run 4 units, but not clear if that refers to the transformer rated for 0.760A, or a different larger transformer. I read all of the old comments and never found a comment which confirmed the current consumption of a working unit.
So it would appear that either your unit is drawing more current than expected, or more likely the capacitors are at least down to half the capacitance they should be.
With new capacitors the voltage will probably be just barely OK, but assuming that your AC line voltage was close to nominal, it is possible it could still get noisy when the AC line voltage drops (e.g. on a really hot day if you live where every building has air conditioning, or a really cold day if electric heaters are common in your area).
no heatsinks on 5v regulators
It never hurts to have heatsinks on regulators, so I would consider adding heatsinks on those.
I live where climate is mild, so everyone is heating and cooling with air conditioner.
I will add heatsinks, check/replace capacitors and buy larger trafo and see it will work.
It's a balancing act between guaranteeing the regulator never goes into dropout under worst case conditions (lowest incoming AC, highest current draw, etc) and not abusing the regulator with unnecessary heat dissipation.
Secondary voltages are supposed to be specified at rated load current, so if you need 0.7 amp for one unit but want to power 4, you should be looking for something that can supply over 30 VA on the 8VAC supply.
