gswan
[quote author="clintrubber"]
Four options: internal 12.288MHz or 11.2896 MHz Xtals for 48/44.1kHz,
or wordclock or optical in (ADAT).
Wordclock uses a 4046 PLL.
Schematics are in the GroupDIY Gmail account:
Go to http://www.gmail.com
Username: groupdiy
Password: thelab
[/quote]
Thanks Peter, I got the schematics.
The internal clocks are simple single-inverter xtal oscillators. An interesting measurement on these would be short term variations (jitter) as well as changes with operating temperature affecting the LRCLK. I'd suggest that the internal clocks are far more stable than using any of the external clock options though.
Another interesting note is that the VA rails are derived using 7805 devices. These are usually far more noisy than the LM317 devices so upgrades to the PSU may be worthwhile, particularly since the AD Vref is also derived from this rail. Having a cleaner, better adjusted Vref on both AD and DA might help. I'd have to open one of these up and stick a CRO on it to see.
Edit: I also noticed that the +/-15V rails are derived using 78 and 7915 devices. Also known as noise generators. Interesting that they get 15V from one 7815 and 17V from the other according to the schematic...
cheers,
Geoff
Username: groupdiy
Password: thelab
[/quote]
cheers,
Geoff
