777funk said:I just read the description on Chunger's page and it's mentioned that this has less of a treble lift than the original and works with a flat circuit.
kidvybes said:...I have that 35mm 6-micron K67 capsule that Chunger offers in a few of my mics...it does not exhibit the typical undesireable top-end characteristics found in many of the cheaper chinese K67-type capsules...it should not result in an OVERLY bright (think hashy or brittle) microphone when coupled with flat circuit...still a bit bright BUT surprisingly smooth performance for such a low cost...IMHO, I would classify this capsule as the best of the chinese K67-type capsules being offered for around $100 or so...ask Chunger how it sounded in his 47-clone...
...if you really want to assure yourself a darker result, I'd recommend microphone-parts.com's 32mm 6-micron RK7 capsule (all brass)...this capsule's response is less bright than their 34mm 3-micron RK47, and offers a nice round top-end...
...but if you decide to try Chunger's K67, make sure it fits thru the headbasket opening on the SP1, since it's an oversized 35mm capsule...
777funk said:Interesting. So I'll end up with SUPER bright then I'd guess. I've read that this is the Schoepps circuit in the SP1.
Re Chunger K67, I just got one I have no other K67 to compare to Im almost dissapointed as it doesnt sound overly bright !.......(shouldnt moan really) Great value !.... I have only done a few tests so far, its seems to sound good in flat circuit mics , sounds similar to a Tim cambel I have ....... I wanted a K67 to try in a U87 & U67 mics I have buts sound a little too dull with the feedback engaged......
ACTUALLY... I just read the description on Chunger's page and it's mentioned that this has less of a treble lift than the original and works with a flat circuit.
