Best Desoldering machine/gun/tool...
When I did bench work for a known audio company, when we first started, we had the pace de solder tools. They would clog often and were a pain to sort out, but when they were working, was o.k. it did the job. But when we moved locations, we were into hake territory with the hako de-solder gun. boy what a difference. Much better all around but still had minor issues now and then.  When I left and didn't have access to that anymore, I picked up a circuit specialist desolder gun for around 130 dollars. Boy if that didn't beat all of them. Made in china, variable temp control, never had a clog I couldn't unclog quickly and is  easy to take part should the need arise.  Oh and it looks like they price dropped it a few bucks.
https://www.circuitspecialists.com/csi8900-portable-desoldering-system.html
I see this one pushed on FB ads recently
https://figgywows.com/products/desoldering-suction-pump?fbclid=IwAR00MUTWtg2GhoGRVw5dwdsS0BP-I9tOQ9SXrVEGA0DJQiNukc3MroXyIUc
I'm in the market for one that'll do I.C.'s in plate through boards, I don't need one that often , but you know....when you do!
I've been happy with the eBay special 915. They require cleaning more often than the Weller I had, before it broke. The 915 is also more fragile. It works great though. For under $125 it's hard to beat. I broke the gun on the first one I had. Once I figured out how to empty the glass chamber without breaking it I was set. I bought a second one just in case. I took some fiberglass electrical tape and taped around where the nozzle meets the body. That's a mechanical stress point and is weak. I broke the first gun there as well as breaking the glass tube. The tape provides extra stability.
I'm in the market for one that'll do through I.C.'s in plate through boards, I don not need one often , but you know....when you do!
The best thing for that is a weller desoldering block (see link).  It's much better than trying to clear through plated holes with a gun & then trying to remove them.    The ic's literally fall out, & are so clean you could reuse them.  I then use a Hakko to clear the holes.  I got mine for £16 from ebay rather than £89 though.
https://www.ebay.co.uk/p/1339374447?iid=181883198226&chn=ps&norover=1&mkevt=1&mkrid=710-134428-41853-0&mkcid=2&itemid=181883198226&targetid=908661247816&device=c&mktype=pla&googleloc=1006565&poi=&campaignid=10204071489&mkgroupid=107296306292&rlsatarget=aud-629407027825:pla-908661247816&abcId=1145987&merchantid=100513064&gclid=CjwKCAjw_qb3BRAVEiwAvwq6VlIrZcIvdmP9YTKl2AlZVGDDsgdVuo5_cLuwPtclEXPyGNgnD8qgOxoC-nEQAvD_BwE.
My honeymoon with the ZT915 is over. The second gun just broke trying to clean and replace the glass tube.  I removed the glass tube to clean it. When I put it back I couldn't get a good seal no matter what I did. Eventually the back part that slides broke. I wasted a good hour screwing around with it.
As of now I spent as much as I would have for a Hakko FR-301. The 808 lasted me years until I dropped it and it broke. I just put the order in for an FR-301.
I've used the Hakko FR-301 in a work I did and I really liked it.
I really want to buy that unit for myself in the future
I got an FR-301 last year, and wish I had bought it 10 years ago.
It's glorious on multi-pin connectors, through hole components etc.
It. Just. Works. First. Time.
amazing.
