Soundcraft Spirit Live (1990) mic input gain reduction mod
mihaelbele
Member
Zagreb, Croatia
It seems that mic preamps have +10db gain when the gain pot is in it's zero position. Is there a mod to reduce gain to unity at pot zero position? Or even implement as trim/gain function? I think that the mod would affect the line input gain too, so I would probably leave few pairs of inputs as they were.
I'm mostly using electrets, and can only resort to resistive pads if mic capsule has a built in FET, but even the AKD D112 gets clipped when used in bass drum.
I've found a channel schematic this thread: link
Try reducing the values of R17 and R18. To drop the gain 10 dB you want to reduce the 12k to 1/3 or roughly 4k.
Maybe only modify one channel first to see how it works, before doing more.
Couldn't you also increase the value of R16? That looks like the classic instrumentation amp front end where decreasing resistance increases gain, and R16 sets the minimum resistance when the pot is all the way at one end. Changing R16 has the benefit that you don't have to worry about matching the replacement resistors (although for that class of device they may not be matched super closely to start with).
No.. R16 establishes the maximum gain not minimum gain (OP's complaint). You would need to replace the 5k gain pot with a larger value which also involves an unusual non-linear taper making them even harder to source.
It's commonly known as a "Cohen" topology.
minimum resistance commands maximum gain...
I would recommend using 1% resistors for R17 and R18, I didn't suggest a specific value because I don't remember them all. Should not be hard to find.
