mjk said:GOSS = Grain Oriented Silicon Steel. Apparently most transformer steel contains the element Si... something to do with increasing the electrical resistance while not affecting the magnetic properties.
I obtained some by unwinding the core of an old toroidal power transformer with open windings. Actually it was a new Hammond right out of the box with an open primary
Magnetic shielding floobymaterial is also available at http://lessemf.com in small quantities
I spec power transformers for 2X-3X the load VA if using capacitor input rectifier filters. For 15-25VA load I would use a 50VA transformer.
Still awaiting the results of my own toroid shielding experiments. Another possibility is to reduce Bmax and potentially reduce radiated EMF through using a buck winding on the primary; drop the voltage down from 120V to ~110V.
Michael
schmidlin said:Thanks Michael, I've seen this site before, with interest but confusion. Any suggestions as to which floobymaterial there will work for the GOSS application of a toroid?
Sredna said:
gyraf said:link is "unprintable" in this forum software, you need to look around a bit at that site.
pdf datasheet: http://www.antekinc.com/pdf/CA-xxx.pdf
Looks very good indeed!
Jakob E.
mjk said:schmidlin said:Thanks Michael, I've seen this site before, with interest but confusion. Any suggestions as to which floobymaterial there will work for the GOSS application of a toroid?
Not yet, but in a few days I'll have some results for a few different materials and configurations using my ultra-sensitive near-stray field detector (aka "microphone input stage"). I purchased samples of 3 different materials plus I have some GOSS strip from unwinding the Hammond core.
The lessemf.com site is full of EMF fear-mongering but a convenient source for internet ordering. There is another web source I used in the past but it apparently has a lower googlerank these days...
What are the parameters involved ?
