Been looking at ways to incorporate an aux send for an 8 channel line mixer. Not really practical for use of PC boards/chips here. The schematic below is my best hack attempt to come up with something simple that does the job and I wanted to get some opinions/suggestions on it before proceeding to the test bench.
The 8 input sources will be 600r and are mixed in parallel with pots for send level on each channel. The amp is pretty much straight out of the RCA tube manual. I don't have much experience using cathode follower circuits so bear with me. Expected mixing loss looks like 17 to 18db for 8 channels. Load will be the inputs of digital delays/reverbs.
Am also in question as to what the best value of the mix resistors/pots should be - 5K or 500K? The incoming line will already be terminated with 600r resistor.
