We just love paying taxes in the UK! Thankfully these amazing looking capsules are reasonably priced even with the tax and imports. If only I'd known when I made my Fet47 a couple of years ago!
Thanks so much for clearing this up! I didn't see the UK shipping option before, that makes a lot more sense now.The k87 capsules are about 2 weeks out right now. We're finishing enough for everybody plus I'm going to add some single diaphragm ones to use up more of the Overstock plates. Yes, cardioid Omni just would have slightly unbalanced figure 8. If your use of Figure 8 is not critical, you can comfortably buy the B stock ones. My shop software doesn't allow for Dynamic tax based on shipping option for some reason? Seems like an oversight. So if you select UK shipping DDP the tax is in the shipping charge instead but it will be prepaid, don't worry
keep in mind "economy shipping ddp" is evri so it depends on how good your local evri delivery drivers are. if they've given you trouble in the past, it's better to pick dhl ddpWe just love paying taxes in the UK! Thankfully these amazing looking capsules are reasonably priced even with the tax and imports. If only I'd known when I made my Fet47 a couple of years ago!
i'll handle it however you put in the order notes. the shipping is cheap, so i don't mind splitting it up. as for the k47 cardioid issue, i think it's just a matter of the cart not updating and you already had one in there. just set the correct quantities in the cart. also, don't use this thread for this.would you wait until you had everything in my order ready before you ship? I only ask because I'm looking at a list of items but I wouldn't want one of them to delay the whole order
how do the color codes relate to whats marked on the board?
Hi @theomCan someone help me with the correct wiring for a UTM0587? how do the color codes relate to whats marked on the board?
Also there is a yellow wire I dont know about on the UTM.
Here is the data sheet. Has anyone else used one with this build?
Thank you so much.@theom
Connect UTM 0587 as in the picture.
YEL connects together with BLK.
If the D-87 will not be in phase with any standard microphone (condenser or dynamic), then you must reverse the VIO and GRN wires of the transformer.
Hi Theo!Next Question:
Trimmer pot pinout:
Solder pins 1 and 2
Leave pin 3 open (cut it so it doesnt touch the pad on the board)?
And on the board, which of the 3 pads are 1 and 2?
Again, Many thanks
Theo
But I must have something wrong.
needs 50dB of gain to get anything usable, and has a high noise floor which would make sense.
Hi @theom !Mic is working!
I will start looking for a incorrect value component,
Pattern switching and pad are working as expected.
It's a journey,
Mic is working!
It's a journey,
I guess you might've gotten everything soldered up, but sounds like you expected this to be some "fire & forget" type deal..? So you haven't bothered going through the entire build guide, to the end?
https://www.vintagemicrophonepcbkit.com/Neumann U87 Build.htm (spoilers - it's in the first post in this thread)
it's hard to look for alternatives without the part number.
