Interesting to note that the circular coil structure is in theory, the best way to go, as far as uniform field, ease of winding, etc. but, as you know, not too many people wind this way. They like the inner layer to be a close as possible for max coupling.
In this case, the distance between the sec and core balances the distance between the pri and core. And the pri is now closer to the outside legs of the core, where the mag field set up by the ribbon motor current can impart a signal.
The tiny core seemed heavy, I wob=der if there is any cobalt in there.
Do any of you guys over there have access to someone I could email at Beyer to ask a few tech questions, or are they pretrty tight lipped?
I woiuldn't be, as there is no way in heaven that anyone in their right mind would ever attempt to reproduce this transformer, in fact, without the weird lams, I do not see how. Better to buy it if possible.
I could not count sec turns due to the wicked varnish, gosh darnit. I hate when that happens, but I guess we can experiment with a different sec turns count underneath a 10 turn primary, ehh?
