Analog_Fan
Would this improve?
Normal you emitter would be grounded and you need at least 0.65V at the base to make the transistor start doing something.
If you lower the "potential" on the emitter would you make the led start glowing at 0.05V at the base?
12÷(12000+820) = 0,000936037 Amp.
12000×0,000936037 = 11,2324 voltage drop.
-12 - -11,232444 = -0,7676
Correct?
