Orchid0
Member
- Joined
- Jan 10, 2014
- Messages
- 5
I received a free big muff that had both battery and 9 v jacks ripped off and missing components. I have the entire unit working aside from when I push the button the pedal engages and works fine when I push it again (into bypass mode) it cuts the sound instead of passing the clean signal. Any advice? Ive tried to find schematics but there are so many versions of this pedal.
*Edit* The only thing Im not sure of is On the input jack I have hot tip sleeve ground and nothing on the ring (but Im not using 9v power just power supply.)
