It supposed to be a Neve clone, but it's not a 1:1 clone.Is that a Neve clone?
If so you probably need to correctly set the Bias so that you have symmetrical clipping.
There should be a trimpot inside the unit to set the Bias point
The supply voltage is 24V.What's the supply voltage? I believe the originals run on 24v...
A really important thing, did you contact Black Lion describing the problem?
It's a Neve clone with cheap parts and SMD components?It supposed to be a Neve clone, but it's not a 1:1 clone.
Hi Astuck,Reading this post, I've nothing to loose so, I'll try the "Smilan mod" with a trimmer and I'll get back to you asap.
Yes it's a clone with cheap parts and SMD components, but not a 1:1 clone, see the mic amp stage for example:It's a Neve clone with cheap parts and SMD components?
It would be nice that a company offered to mod the B173 unit, a Tweakhead Max High whatever name Mod, for the same price Black Lion asks for modding perfectly working piece of gear....
It’s a bit sarcastic that people pay high amounts to black lion to mod their gear, when black lion is not even able to do a simple cloned Mic preamp
Can you describe "too noisy"?I got one of these in a trade, OK as a DI but too noisy to use as a mic pre.
Thanks, I'll replace the trimmer with a fixed resistor
