Rybow
abbey road d enfer said:What do you mean "maxed"? Do they burst in flames? The operating temperature for these resistors may be above 50°C, which is where it starts to burn skin.
By “maxed” I mean the bias & balance trimmers are near the end of the available adjustment, at which point the resistors got so hot that they have melted the PCB underneath & blackened the solder points.
Are you sure? What's the "correct side"? The voltage should be measured across D27, that means one probe on each side, not between ground and one point. In particular, between ground and pin 4, you can only expect residuals. That's between pins 3 & 4 that you need to measure.
I meant the positive side of the diode. I know it says across d27 in the instructions, but the few videos I saw showed people going to ground. If I measure across D27 my meter is pinned to 0.00 mV.
Pins 3 & 4 start at around 1mV, and then there is a slow climb (40 minutes) to 5.1mV where it came to rest (total time I measured for was 1h 20 mins or so). Adjusting the trim pots has no effect on the voltage.
That's about what I would expect to find there
No. Your meter cannot load a 1 ohm resistor. It is normal to see a surge then a stabilized value.
Ok. Good to know.
I am considering getting another matched set of power tubes for testing.
