Echo North
rjd2rjd2 said:Thanks. Here's where I'm at:
I built a signal tracer. I printed out the schems and have the exact signal path. with the power off, i traced the circuit. my problem is that the signal stops at the input transformer on BOTH of my units. (building a pair). i get a sort of loud hum with no signal from there on out.
i have quadruple or quintuple checked my wiring against the instructions. it all appears to be EXACTLY per the hairball site instructions. input xlr pin 1 is tied to chassis pin on xlr, ground continuity follows thru to the shielding on the cable between input tranny OUT and PCB IN.
here's the part that is stumping me: i unscrewed the input tranny from the chassis, and for one 5 minute stretch, the signal passed thru the input tranny. i traced it all the way thru the circuit to the output xlr, and it was all continuous. when i reassembled, it went back to no signal.
i can't tell, but it SEEMS as though there is maybe a short from ground to the signal outputs at the input tranny? since both units behave the exact same way, i have to assume there is some user error going on here. but for the life of me, i can't figure out what it could be.
with power not running to the unit, should i be able to trace signal past the input transformer? thanks for the help, really want to wrap this project up, it's kicking my ass!
How are you coming a long with your issue?
