Hairball Audio said:Mr.Franky said:Hairball Audio said:You need to trace the signal to see where is stops.
Feed a 1K 0dB signal into the input. Set your controls mid way, no GR, and test the signal referenced to ground at the XLR pin 2, + in t-pad, +out tpad, + either side of the input transformer, + at PCB input, - side of C7, and positive of out XLR.
Don't worry too much about the AC value they'll go down then back up. Just look for the point where you get no reading (less than say 0.050 VAC).
Mike
Hey,
The signal seems to stop at the output of the input transformer. It is installed correctly though. How could this be broken?
Regards,
Damaged winding if anything. Check it at the output side + pin to confirm it's not a lifted trace. Check the DC R (ohms) between the + and - out put pin.
Hey, I am in fact getting signal at the output of the input xfo. 070 VAC when the input control is mid way. When input is fully CW, I get a value of 0.394 VAC. I thought the value of 0.70 VAC was too low, but I suppose it's not. I'll keep on seaching
cheers
