eriksunding
Active member
- Joined
- Jul 9, 2017
- Messages
- 29
SOLVED! Faulty cable going from main pcb to ratio pcb. Two of the small wires had changed places with each other. Factory fault I assume.
hrasmus said:Hi, i need some help fixing my Rev. A build, it works correctly most of the time, but some times it starts to act up.
The GR- meter slams to the left and it compresses heavly, then it slowly recovers and all of a sudden compresses again, totally unrelated to the input signal.
When ever i try to investigate what might be causing this behavior it works fine. My guess is it is some how related to the ratio switches, because i was able to opperate with out problems for a long time as long as i kept it on 4:1. The GR meter slams to the left when i switch between ratios and then recovers after a few seconds, i don't know if it's supposed to be that way?
Thanks for your help![]()
Hey all I'm just in the midst of calibrating a blue face - quick shout out to Mike/Hairball for STELLAR SERVICE!!! I'm using an old toroid at the moment but he is speed shipping me a replacement. Many thanks!phatmateo said:ER. I always had problems calibrating the meter in step 3. I have the version 1.0 pcb with the suggested mods. I ended up getting frustrated and just calibrating the meter to about 7 or 8 db reduction. My unit compresses like it should, but something is funky with the meter that I never figured out
Phrazemaster said:, and the FETs are Hairball matched.
This doesn't rule out something still wrong with the transistors, however.
You're the best Scott. All you guys. Thx for the community. I will check out the video. I'll be going to my studio tonight to do some more hand-wringing and attempts to repair and troubleshoot my Rev A beast!scott2000 said:
I'd definitely take troubleshooting any day over heartache. Worst case I ever had was about two years. Time does heal . In fact, I can't think of anything good that came out of the certain times when I was being sad during the heart break. Except maybe weight loss....lol
Don't ever break up with us!
We need you...
This is an interesting video about matching...
https://www.youtube.com/watch?v=hSFqkJn67eI
Good Luck!
