Biasrocks
I would suspect the power transformer not giving enough juice.
Have you monitored the power supply to see how it's behaving?
Mark
Mark
evilcat said:the voltages will be +30 and -10 V anyway, isn't it ? The PSU section modify the voltages whatever transformer you put in front of it ?
0dbfs said:That is correct.
The diodes in the PSU section will rectify the AC from the PT to DC, the caps will smooth it, and the regulators will bring it down to the desired voltages. The regulators do have limits but the 30+30 is within those limits. Read up on the datasheets for those parts. The stand-alone PSU that mnats included is pretty cool, flexible, and easy to tweak for different needs if you are using the on-board PSU, you can use the extra PSU board for a variety of purposes.
phatmateo said:http://hairballaudio.com/docs/FET_Compressor_PCB_Board_Info_V2.pdf
phatmateo said:Mike, you are making it too easy!!!! I'll post pictures of my completed rev D build with everything hairball soon![]()
Echo North said:I was thinking of adding a "Completed Builds Gallery" to the site as well.
Mike
