oh man I want a pair of these!
MicDaddy said:Has anyone noticed a drift in the VU meter? This has barely burnt in, possibly it will loosen up some over time?
Randyman... said:Bump for Echo/Mike for my post on the last page (last post on page 45) about swapping C1 & C8. Any input?
Thanks! 8)
diyfanatic said:hi guys,
small question here as I didn't found an answer in the thread!
- C11 is listed as 10pf on the BOM and on the schematic but 47pf on the pcb, wich value is correct? (I guess 10pf)
I've found that on the mousser cart from Hairball C18 wich is 47uf is listed twice...
cheers.
Jr.
(what I get for not checking off the BOM)
so you use the 10pf? no problem here?
evilcat said:What do your voltages say before and after your T-pad ?
If I remember correctly, you should have the same voltages when the T-pad is at the max. And then lower output voltage than the input when you lower your T-pad.
Ben
bieckmusic said:c27 is listed as a .012 uF capacitor but in my bill of materials I have a .01 uF 100Volt supplied and left over. Apparently this is the cap for the Attack Potentiometer. Will the .01uF work, or should I try and find a .012 uF?
