0dbfs
Looks like there should also be a negative DC voltage between pad 21 and ground that offsets the sidechain audio. If the sidechain audio is not high enough, the diodes will not conduct and make the CV...
-j
-j
0dbfs said:Did you use 2n3707's or other in there? I guess if there wasn't enough signal in that section for some reason then that may affect something.
0dbfs said:Interesting about touching the attack pot. Is something in that section shorted to GND? How do you have the ratio board grounded? Is there only one path to ground? Can you change the grounding of that part around to see how it changes things?
0dbfs said:I eventually ended up wiring that section point to point n the back of some switches instead of using the board.
0dbfs said:No audio is expected after the diodes since it is only a positive going waveform at that point. What are your compressor input/output settings? Can you turn input up and output down with no changes (for more compression)?
0dbfs said:Does the GR meter show reduction (like the audio does) when you adjust the Q bias pot with the sidechain bypassed (GR-OFF or pad-22 to gnd)?
0dbfs said:Looks like there should also be a negative DC voltage between pad 21 and ground that offsets the sidechain audio.
0dbfs said:Yes s4b is the threshold and s4a is the ratio.
I wonder if the diodes are getting enough audio signal to conduct? I think they need +.7V to conduct but not sure right now. If you send a tone through you could set your meter to ac to measure that at the input to the GR amp and output.
0dbfs said:I was also thinking that you could just bypass s4b and connect pad 15 straight into the GR amp (so it's full level) and then set the ratio switch to 4:1 for minimal threshold.
If that causes compression then maybe something is up with those 4 transistors in the GR amp. Maybe the s4a is dropping too much signal to the sidechain. Are the resistor values there correct? It's recommended to measure before stuffing/soldering each component just to confirm if nothing else.
Getting close now but no smoking gun. At least R32 hasn't burned up.
J
0dbfs said:Randy, I am following your efforts here with great enthusiasm and must commend you for your determination and persistence in moving forward with this. Thanks for your inspiration!
0dbfs said:I would expect that the GR amp has to put out enough signal at Q8 & Q10 to offset the -DC at Pad 21 such that the signal is in excess of 0.7V to get past the diodes. Looks like you have proven that this is not the case at the moment. Good news as far as I am concerned because instead of an unknown it appears that some absolutes have been added to the pool of knowledge.
I don't know the specifics of troubleshooting the GR amp but looking into the configuration of each of the two sets of transistors Q7/8 & Q9/10, they are each set up in a common-emitter-stage -> emitter-follower-stage. Looks like Q7 & 10 (common-emitter) should provide gain while Q8/9 are unity gain and impedance conversion to drive the 47k output of each amp. ie; That combo of stages appears to provide gain, polarity inversion, and a low impedance for the following stage.
I believe that the R39 + R41 to GND (~5k) set the gain of Q7 (common emitter). Q10 has R48 + R50 to GND (almost 8k). Q9 also has a voltage divider at it's input which would attenuate the signal from the previous stage so that may have been part of the design to get each end of the differential output at the same level. I'm guessing that audio at the collectors of Q7 and Q9 is supposed to be higher than the audio at pad22 and the audio at the emitters of Q8/10 should be slightly lower than that at the base of Q8/10 (since the emitter-follower-stage is supposed to be slightly less than unity). Also, the 22k connection from the junction of Q10E/C19+/R49 back to the junction of Q7e/R39 looks like an NFB(?) loop which would both reduce overall gain and provide stability/linearity.
DC voltages around those parts would be important but I can't say right now what they should be although I would like to understand/know that based on the 30V supply, the various resistors in those circuits, and the properties of the Q's. Looks like Q8/10 should have 30V at the collectors. From there, the dividers get more complicated and may involve internal impedances of the Q's based on their particular operating points.
In any case, looks like the signal at the input of the GR amp is much lower than the output and this may be where the problem lies.
I think I have read around here that some use 5088's (?) instead of 3707's or 3708's.
j
dustbro said:Just powered up my 1176. The unit works and sounds great!
I'm noticing quite a bit of physical "buzz" noise coming from the Hairball toroid when its powered up. Is this normal? Again, everything works, and the audio has no buzz... just the toroid.
Rob Flinn said:Randy
great to hear you made some progress. I bet everybody here has made the meter range mistake... I know I have !!
0dbfs said:Awesome! Congrats on the acquisition of two great brand new
handbuilt reduction machines! What's next on your list now?
Jonathan
