pictures always help, and are just plain fun to look over
MicDaddy said:from nimbleswitch-
Step 3: Adjust Gain Reduction Meter Tracking
Ok. .775v coming in.
* In GRmode, Input control at 12 o'clock, and adjust output control
to give .775v coming out of the unit.
* Now, switch to bypass, and adjust the input control(the t-pad)till
your output of the 1176 reads 10db(2.4495).
* Then switch back into GRmode and again readjust the output
control(of the unit) to read .775v at the unit's output.
* Then switch to bypass yet again, and readjust the input
control(t-pad) till the unit's output reads 10db(2.4495).
* This goes back and forth a few times till the 10db swing
holds...i.e, in bypass mode you have 2.4495v coming out, and then
switching into GRmode, you have .775v coming out. Thus the 10db
swing...10db of gain reduction.
* Immediately insert R44 with input signal still present and adjust
it till your internal VU meter rests at -10dB. You'll probably be
quite close to this setting without adjustment.
It's been my experience easier to 'see' what's going on with the DMM than watching the VU
ChrioN said:This is so strange. Signal disappears after the input transformer. All resistor values checks out.
Anything obvious going on?
ChrioN said:Yes, measuring on the pcb at the input pads, no signal. I've tried two transformers, same problem.
ChrioN said:Yes to all questions, and yes I've measured at the output pins of the input transformer, so no wire problems.
It often is the elementary parts that is the problem. Any other suggestions? I apreciate it. Thanks.
ChrioN said:Note that the t-pad comes before the input transformer. No problems there. Its after the input transformer the signal gets lost.
MicDaddy said:ChrioN said:Note that the t-pad comes before the input transformer. No problems there. Its after the input transformer the signal gets lost.
:been awhile since I've been inside her... (insert joke here)
the leads from the input that terminate at the pcb.... with these removed do you see signal on these wires?
ChrioN said:Yes, there is a signal when the wires ain't terminated to the pcb so the problem should be somewhere on the pcb.
So signal from transformer PCB until you connect it to the main PCB at which point you know longer get signal from the output of transformer PCB... Must be shorted PCB input +- no? Or the signal from transformer PCB isn't actually connecting to the PCB input.. ie. lifted trace/dodgy wire/dogdy molex etc... Or the 270R is a stupidly low valueChrioN said:This is really driving me nuts. I've completed four 1176s over the years, so I know this project fairly well.
Anyways, I've attached a picture of how I've wired the input.
