Echo North said:
Congrats on taking a step toward some deeper understanding.
Electrons are not really free to roam around. Electrons flow (actually passed between atoms) between two voltage potentials, towards the more positive.
I don't have time to draw it up right now but let me try to attempt some basics of the circuit and provide a link. For reference, I'm looking at: http://mnats.net/files/1176REVD_VOLTS.pdf
Thank you! - No problem mate, any info is great
Did believe they travelled to the positive and then somehow 'convinced myself' they followed the inverse... Last time I did electronics was well over a decade ago
Time flies.
Echo North said:
Think of the GR FET as a "trap door" and it's closed now so all of the signal passes
Yes I've grown to understand the purpose of BJT's, MOSFET's and the like - Found a very intersteing article on this forum regarding VCR FET's and incorporating feedback to realise linearity
Still learning, though - Need to revise these NPN BJT's.
Echo North said:
That top 1/2 of the schematic is the only place the audio signal that you hear at the output travels.
Yes, now that you say this, I can make sense of it. What goes on elsewhere is added to the the signal - to attenuate or otherwise.
Echo North said:
The signal travels through S4A where the it is decreased via that resistor ladder that depends on ratio selected and feeds into C17 where it goes through the gain control amp where the NEG swing inverted so the AC is all positive.
Aha! Yes, I missed this inversion - begining to make more sense. Just to make sure - S4A and B are actually connected (red line indicative of this I believe?), what you do to one is refelcted by the other to realise/impose this 'negative DC voltage down to the control amp'.
Echo North said:
sends a negative DC voltage down to the control amp. The play between these two voltage and the CR2/CR3 diode create a DC voltage that is sent back to the gate of Q1
Feeling greater understanding - The output is all on it's own, nothing more than a gain stage to output. Everything happens at/after the input, and fed back to Q1 to compensate.
Out of curiousty, and with the Capacitors in mind these take time to charge - Is it agreeable that this time coefficient is negligable on the resulting 'signal'? Noticed C27 (running parallel to R54 with the variable resistor to make up the attack parameter) is 0.022uF. Others like C1 are significantly greater. I am going to have to read up more on these.
With C7 in mind, this inversion (from what I can make out) into signal line amp (output) doesn't seem to flip back to positive ??? Does C8 adhere to this?
If I have grossly misunderstood somewhere - Deepest apologies! This is something that in the last two weeks has fascinated me - Realising it is proving easier with each new learnings acquired. Who on this planet, original or not, would reject an 1176? Going to revise this all further, and in the coming days begin a seperate thread, with all purposes to pose my understanding of this units function,.. And pose further questions - I'm taking up too much space on this thread :
If any one with further learning resources would like to forward - Fire away
[email protected]
Best regards, and thank you for the other readings - most appreciated! ;D
