skidmorebay
- Joined
- Aug 1, 2011
- Messages
- 136
I'd ignore the meter section for now and focus on the no compression issue. Have you confirmed by measuring the output that you're not getting compression?
If you're not getting compression check:
With in/out knobs mid way apply a 1khz 0dB signal and adjust the output to 0dB on the output
- that you see ac at pad 22 that starts larger and get's smaller as you move from ratio 20 to 4.
- that you have a negative DC voltage at pad 21 that starts larger and get's smaller as you move from ratio 20 to 4.
Mike
Mike,
Thanks for following this thread closely. I waited until I was at my wit's end to post a question….
I didn't want to fill up the post with all the measurements I had taken…
Good news is I re-set the Q-bias and I believe I am getting compression now.
I checked for compression by setting the longest release time, sending a 0dbu 1khz tone in, and cranking the input while lowering the output. While switching the Attack knob from "on" to "off" I can see the waveform rise either slowly or relatively quickly, depending on where I set the Release knob. So that's good.
Applying a 0dbu signal, adjust in/out knobs so that Channels 1 and 2 on oscilliscope are both showing a sine wave at 0.775V. (Ch1 on 1176 input xlr, Ch2 on output xlr) Using the DMM I got:
Ratio AC@pad22 DC@pad21
20:1 0.701V -5.85V output goes to 0.922V
12:1 0.342V -3.25V output goes to 0.775V
8:1 0.228V -2.45V output stays about 0.775V
4:1 0.114 -1.63V output goes to 0.738V
But the VU meter still stays stuck below -20db when switched to GR mode. While trying to get some life out of the VU needle I found I was able to dial up the drain voltage of Q11 by fiddling with the Null Adjust and Zero Set pots. I was only getting about 4V at Q11 but now I have good voltages on Q11 and Q12. But Q13 shows -1.3V at the Base, -0.1V at the Collector, and -1.6V at the Emitter. I have 8.98V at TP10 and -0.8V at TP11.
Like I said earlier, the VU works great at +4 and +8, but is dead on GR.
I've checked the wiring again and again.
Think I'll call it a day...
Mike
Mike,
