Stagefright13 said:
I can send you a new set. Or even if you want to make a lorin switch board and just swap the whole assembly out.
Sorry I missed your message. but thanks, that was really kind of you to offer! I did, in fact, lift a pad on the ratio board, but I managed to work around it.
And thanks for the advice. I had a couple intractable problems, so I hired a great tech who lives nearby to look at it. He brilliantly and methodically quashed all the bugs.
It turns out that:
a) my biggest and most boneheaded error was that i had incorrectly wired the output transformers (that took care of the gain problems).
b) one of the two units required a resistor change in order to perform the null adjust step.
c) the other unit had a faulty trim pot.
d) Q1 (which i didn't bother to match) was giving sass on the 2nd one. Even after seemingly passing the Qbias step, it wouldn't limit. Socketing it and swapping in another fet did the trick.
it goes without saying that i probably should have attempted a simpler project... but now that it's done i love it.
I've only used the Purple MC77, never a UREI, but I find the revA clone compares quite favorably. So far I've run clean guitar, female vox and bass through them. They work great on all of these sources.
