This is precisely the sort of thing that caused me to stop before trying to build my kits, and take some time to educate myself on things I did not understand well enough, such as how different kinds of power supplies work, how to better use and get the most out of my test equipment, such as the multimeters and oscilloscope. In this time I've gone from wondering if I'd bitten off more than I could chew, just a few short months ago, to researching mods and alternate componants for my compressor kit. It occurred to me very quickly that this (and everything else on this site) is a DIY project. Meaning no one was going to hold my hand, I had to do this myself, and mnat's warning (copypasted above in red) was what really got me thinking! I was not prepared to build this when I purchased everything back in March, realized I needed to brush up on basic electronics, and here I am today devouring books on active filters and op amps!!! I never would have guessed this project would turn into a crash course in what has suddenly become my #1 hobby. I've picked up a nice soldering iron, and piles of tools, cutters, strippers, you name it, spools of various wire, organizers for my parts, my living room has turned into an electronics workshop!
mrtomcat, the reason we aren't willing to give step by step instructions for checking the PSU is build corrrectly before turning it on is because no one is willing to be responsible for anyone getting hurt, killed, or burning down their house. Now that I understand how the power supply works, I'm comfortable moving forward with my build. For me, I read these threads (Rev A, Rev F, and most of Rev D), the mnats wiring guide numerous times, the new Hairball PDFs, and googled everything I could until I was ready to open existing gear, and carefully probe the PSU of the my equalizers, compressors, etc, and confirm what I'd learned. I even repaired an old Urei 562 that I got cheap because it wasn't working (bad tantalum capacitor in PSU, failed short) and got the satisfaction of applying that knowledge. I further repaired an old Alesis reverb that powered up, passed audio, but the reverb wasn't working, and with some testing on the multimeter I found that it just needed 1 part replaced. A $1 part! Works fine now!
Once you understand how the PSU works in the 1176 it becomes apparent what needs to be done to build and test the PSU yourself. I'm not saying that this is what needs to be done to complete the build, but at least understanding the basics (including the risks involved) will go a long way towards making the builder feel comfortable powering it up the first time. Just in this thread alone are tons of builders who took their time, and still blew a fuse (often wrong fuse), or fried R32 (output tranny wired wrong), but they powered up, taking care not to touch anything potentially energized to mains voltage, and reported their problem.
#1 makes sure you understand which parts carry mains voltage when wired correctly.
#2 makes sure you are using the correct fuse, and make sure you will be plugging into a socket that has some form of circuit breaker, either a GFI plug, and/or a breaker/fuse at the electrical panel in your building. If you accidentally connect live to ground (chassis), and the live has a path to ground, the fuse or breaker will blow/trip. This is there for your safety.
#3 understand that the IEC connector has three pins, and what each of those pins do. understand that a correctly wired 1176 takes power from the IEC, through the fuse there, then through the switch on the meter switch, and finally through the power transformer's primary windings and back to neutral on the IEC plug.
#4 the power transformer's secondaries then become energized to a much lower AC voltage. Everything from the secondaries and all through the rest of the circuit will be at a much safer voltage in this circuit (1176)
#5 learn to use a multimeter to test all of these things, including continuity (or ohms if your meter doesn't do continuity) to test that everything is hooked up correctly before powering on, and how to check volts AC to show your getting the correct voltages in the mains wiring, and on the secondary side too, which is the lower AC voltage feeding the rectifier diodes on the PCB, and also using volts DC setting for testing the rest of the PSU on the PCB, and all the test points shown in the schematics and ultimately during troubleshooting and calibration.
I hope some of this points you in the right direction. Take your time, read everything you can on the subject, and just be safe!!! Once you understand what the power supply is doing it all starts to make sense
