mrtomcat said:I am having trouble calibrating:
First off, the unit turned on great, I measured the power rail again, the meter came on and everything looks fine, so I proceeded to calibrating.
Step 1 (based of the mnats videos) worked like a charm
Step 2 not so much...
I set the jumper as requested, I turned the R71 knob until it reached 0, the test point reading was 0.71 volts, I then set the the zero adjust to go to 0.00 but when I tried to compensate with R71 it had reached it's max. The knob won't let me turn any further clockwise.
So what am I doing wrong? What can I check on? Should that knob (R71 poti) have a max value?
Please help
thanks
Hairball Audio said:mrtomcat said:I am having trouble calibrating:
Please help
thanks
Are you using TP10 and 11 for your DC measurement? IIRC the video's use a rev D which is measured across a resistor.
Like from my build guide:
"Note on calibration for Revision A builders: Measure accross TP10 and TP11 when setting the null adjust as opposed to accross R74 as shown on the Revision D."
If you're doing that are you measuring DC?
Mike
Hairball Audio said:This one can be a bit tricky.
It takes a bit of finesse. Start with the 0 adjust trimmer in the center and set the null trimer to 0. Try to anticipate how one will effect the other to avoid maxing out the zero pot.
If you can't do it, it's possible something is out.
Did you match Q12 and Q13 for HFE?
If those are poorly matched that will cause an issue.
If you can get it below 0.1 that should be fine.
Mike
mrtomcat said:Still no luck. I removed the null adjust and q bios trimmer and remounted them based on a recent picture here...they were reversed but in the correct slots.
I replaced Q13, this one was dead when I tried to measure it. I was hoping the replacement would do it but nada.
still the only way to get 0 is by having the null adjust at .72 vdc
I was told by another user with a similar problem that he had a defective ratio board...could that be my problem?
Other than trying to measure every component is there anything else I can do? The wiring looks right, I went over the videos and manuals again a few times. Everything looks like it should be right... so frustrating.
Anyone?
Hairball Audio said:mrtomcat said:Still no luck. I removed the null adjust and q bios trimmer and remounted them based on a recent picture here...they were reversed but in the correct slots.
Anyone?
Did you check your voltages against the MNATS schematic with voltages on the Rev A site? Which ones are off by more than 10%?
Mike
mrtomcat said:I will do that tonight.
Complete rookie question: What is the correct way to check these?...Is that red lead on B and Black Lead on C for the...
hymentoptera said:Black lead (plugged into COM) on ground, which is the middle pin on the power supply side of the PCB where your AC comes in from the power transformer (gator clip is nice for this). Red lead to appropriate junction in the circuit to be tested. Each point to be tested will be between two or more componants (voltage should be the same anywhere at this part of the circuit), and any of the two or more exposed leads or solder joints at this junction will work for the test, just be sure to not short anything with your test lead (mini-pincers are great for grabbing a resistor leg, etc, and use regular probes for anything else).
All Ears said:A question about tantalum caps...
How critical is the value of C19 and C20 in this circuit ? (the two 6,8uF tants)
Reason I ask is that I have a pile of 50v tantalums that are "marked" as 6.8uF but all of them seem to be testing at 8uF - 8.3uF on both my meters.
Is this a measurement error (ie something to do with measurrment freq) or is it normal for tantalums to read higher than their marked value, or is it a bad batch ?
Would I be better going ahead with the "8uF" tants or just punting for nice modern tight tolerance electrolytics for C19 and C20 ? (maybe a Panasonic or Philips or Nichicon)
cheers - all ears
mrtomcat said:More problems...
I can't get Step 3 to work, and I have noise in my output.
Step 1 and 2 now work perfectly.
Step 3...well I can't get any gain reduction, when I set the VU to 0 via output and then turn on the GR via the attack know the meter drops maybe half a DB. and if I turn it back off nothing changes.
On top of it I have a very noisy output.
I replaced all my audio wire (I was not happy with the wire I used to begin with and replaced it with high quality wire now), when over every connection and did find I had the attack know wired wrong also one of the wires on the little harness had gone lose...I fixed all that and double and then double checked once more that everything is now fine but absolutely no difference.
Any thoughts? The PCB voltages are all checking out
Also what could cause the noise? it's not a ground hum, it's a bit more high pitched
I was so hoping to be done with this by now and to actually use it but I guess not.
I'm digging through the archives but if anyone knows what I should check on please let me know
thanks
