[BUILD] 1176 Rev A - Back to the beginning...
I am still confused. The primary (or secondary for that matter) doesn't have an inherent impedance.
For example, a 1:1 transformer with a 600 Ohms load on the secondary "reflects" 600 Ohms to the primary. A 60 Ohm secondary load will "reflect" 60 Ohms back to the primary. Thus, the amp driving the xfmr "sees" a load which is directly affected by the secondary load.
Or, does that particular xfmr have multiple secondary taps that you are selecting?
Bri
It would be better to load the output not heavier than 600R and get the needed level with a voltage divider.
As for resistors valves, always check with the original schematic. IIRC sidechain is identical in rev A/B and D. Meter driver is different though. Frankly, I would’ve left meter driver circuit from later revisions because it’s much simpler.
The meter driver section itself is not changed. It is the voltage that feeds the Gain Reduction Controller Amp that is changed, which is why mnats put the optional trimmer on the ratio board. I was not concerned about what it looked like on the meter but the actual compression of the audio.
Paul
Just to be more electrically sound, I installed a U-Pad on the output to give me the same reduction (R1/2 = 150, R3 = 600). Frequency response is still the same. I would have liked messed with the the trimmer as I think the trimmer voltage divider for adjusting the overall threshold would have been a better solution than just adding more resistance before R78. Compared to the Rev D in the same box the compression and output levels appear to be pretty close. Once I close this up and put it back in the rack I won't think about it again. I hope.
Paul
It's an absolute mess in there. This was one of my very early builds before I converted it to a Rev A/D in the same box and I was focused on getting the boards swapped and putting back to work and not showing it off at this weekend's bake sale. Using some SMPS's and one of my capacitance multiplier boards to create +30/-10VDC. The additional caps for filtering wound up being unnecessary. I was getting about 0dBu of noise from somewhere I and I naturally thought it was from the power supplies. Turns out I did not have the ground connection for the XLR Pin 1 made on the hardwired bypass boards, so when I connected my bus powered interface I was getting noise injected into the output XLR which then showed up on the meters and also to the computer. I've discovered more than I wanted to find on a project that was supposed to take one day.
Paul
    3.5 MB
Tested it out today. The noise on the high side of the RTA from the image above must be due to the fact that the input to my small testing interface has an impedance of 4k. My studio interface has an input impedance of 200k. When I cranked the monitors I could maybe almost hear the slightest bit of hiss. It's definitely much quieter than before with the SMPS and the capacitance multiplier board. Also, before with the transformer there was a low level hum. That is no longer there.
The difference in characteristics is quite noticeable, much more than I would have thought. I am very much looking forward to putting these to great use this coming year.
Paul
Anyone try running a Antek-0230 25VA ( 2x30v secondaries in parallel ) power transformer with their 1176 Rev A-D,F build , would like to hear your results ? Dont have the time to filter thru numerous posts, searches not turning up anything meaningful , like dead links or current material parts lists. This transformer is reasonably priced. Seems a popular one is 30va with 2x25 secondaries , but not much is the way of low cost alternatives like this Antek.
    649.6 KB
    32.8 KB
