Echo North
Spendor said:Sorry to ask again - I think my problem is also related to the fact that if I connect a 1k 0db signal to the input it suddenly drops to approx 0.25 V ! This happens regardless of whether the unit is switched on or off and even if i bypass the input transformer and T-pad. Any ideas? Thanks.Spendor said:Hi all - I'm building a REV D rotary version. All seems OK regarding voltages and I went through calibration OK. My problem is I have SO much gain! If I turn the output pot past 9 o'clock its audibly hissy. It all seems in the output stage - I'm using a 250k log pot. Is this correct for the rotary version? I haven't installed a trimmer on the ratio board - is that OK? Thanks
You loose 1/2 the signal in the switch from differential to single ended.
Have you checked your amp stage voltages against the MNATS schematic with voltages?
