ln76d said:I assume that you checked all resistors and capacitor values...
Transistors:
2n3708 are well placed
Did you use 2n3391 or equivalent?
Did you placed in proper order all bipolar transistors?
What FET did you use? If 2n5457 - both are wrong placed.
Yes, C7 is wrong placed. Also check tantal capacitors polarization, cause i don't see them from this angle.
For C7, C10, C17 is better to use film caps.
not exactly. The bias could be above the signal and that way the fet won't be conducting.The Ac of xlr output should differ whatever way I turn the Q bias trimmer I think, ye?
Sillen said:Do you mean in his calibration videos? There is no calibration-guide else from mnats that I found. How do I know if it's hot enough?
mitsos said:Thanks for the confirmation... working fine now.. I did have a toggle switch for the link, and it worked fine, but something was not right about the unit. It actually worked fine at my place, but I had it at my friend's for a few months and it would act up there. Once in a while the VU would go from 0 to about -3 and sort of fluctuate back forth a bit (like between -2.5 and -3.5 or so). This was with the meter in GR (of course) with or without signal, sort of like -3 was the new 0. In the end, I think it was compressing, I'm waiting for my friend to send me a vocal he ran through this unit where it happened in the middle of it.
Anyway, I can't say for sure that it was the link circuit, but with so many wires in this box (2 channels in 2U), one less thing will at least make it easier to troubleshoot if it happens again. So far though it's been on for a couple of hours and needles are set at 0. Fingers crossed.
thanks!
audiophreak said:Well ... I replaced all the the 3707's with 5088's in the correct pads and replaced the 5457's with another matched set purchased from another source, verified all components on ratio board - it changed absolutely nothing
I then swapped out the ratio PCB with the one from my Rev.Js as it used the Lorlin switch in stead of the "slam " switch ( in case I wired it wrong ) ... and no change
what I am getting is the QBias and Null adjust procedures go as per mnats calibration videos , but the Gain Reduction meter tracking adjustment - I can only get -5db Gain Reduction , measured the output with GR off ( pad 22 shorted ) - 1k 0db on input XLR , IP and OP controls at 12:00 , the OP control adjusted to 0 on meter I read +1.246 on OP XLR ( aprox +4 ) , then unshorted pad 22 engaging GR , input control almost all the way up and out set to 0 on meter ( almost all the way down ) I get -5db on meter , then measured at OP XLR and got +0.694 ( apro. -1db ) , I assume because meter mode is in VU ?
So today I pulled the main PCB out and verified all resistors in both GR meter driver and GR control amp sections - all checked as they should be, I had a Lytic in C17 , replaced with a poly while I was there , can not test pf caps - DMM doesn't go that low
Before I pulled the main PCB I checked all voltages as per mnats schematic , all the same as I posted back on pages 188 and 190.
I check and tested all the components before I installed them on the PCBs, not that I couldn't have made a mistake , but the test point voltages are either spot on or slightly off .
are the voltages that are slightly off a concern ??
before I reinstall main PCB any Idea's on where I should check / test next ??
really hitt'n a brick wall here :-[
would really appreciate any help with this
mitsos said:mitsos said:Thanks for the confirmation... working fine now.. I did have a toggle switch for the link, and it worked fine, but something was not right about the unit. It actually worked fine at my place, but I had it at my friend's for a few months and it would act up there. Once in a while the VU would go from 0 to about -3 and sort of fluctuate back forth a bit (like between -2.5 and -3.5 or so). This was with the meter in GR (of course) with or without signal, sort of like -3 was the new 0. In the end, I think it was compressing, I'm waiting for my friend to send me a vocal he ran through this unit where it happened in the middle of it.
thanks!
OK, left the unit at "friend A's" studio for a few days. That's where it was having the problem. Presented the VU issue after a couple of days, I picked it up and left it at Friend B's studio to rule out studio/power issues because he's had some PSU problems in a couple of other pieces of gear. Anyway, here again, it was working fine for a couple of days, then, yesterday, while I was there, I glanced down, and the needles were at -3... This is with VU in GR mode, no input, controls have no affect. I opened it up as quickly as possible to take some voltages, and proceeded to check the PSU first. As soon as I touched my DMM probe to the -10V output (mnats PSU), the needles went back to 0... all transistor voltages were in line with voltage chart... but I expected as much because the VUs were already back to normal.
I'm at a loss how to proceed with this, I guess next time it does it I'll measure the GR Fet voltages first... Anyone have an idea?
thanks!
