Hey Josh.
It's hopefully just some confusion in the calibration procedure...seems that way since both meters act the same.
Meter needle drops to -10VU with no signal?
What happens when you inject the signal then?
From what you wrote, two things came to mind, however, ignore any incorrect assumptions.
During tracking adjust, it sounded as if you were using R44 to try and adjust to 0VU instead of using R71?
Still, -10 initially, with no signal, that may be a little far in regards to the needed trim ranges in the tracking procedure...but maybe not.
Secondly, were you implying that you were in GRmode during the Qbias procedure? Or did you just note the meter's position before and after?
If you're using the unit's meter to make the Qbias adjustment, make sure you short pad 22 to ground, so you're basically in "GR bypass" but still have the meter function...don't Qbias in GRmode, of course. That could be suspect.
In regards to tracking adjustments, I assume in lieu of "shorting pad 22 to ground," to keep the meter functioning whilst bypassing GRmode, you're just muting your source signal?
I did the "short pad 22 to ground" to be on the neurotic side, but you should be fine the other way.
So when you're sure about your Qbias, and have then done the Zero meter, 0volts across R74 step....
Here's an outline of my tracking adjust method...maybe it will help:
R44 in
GRmode(20:1)
Your controls set for the 10db swing(10db of GR)
Your source signal coming through...being compressed.
Now, adjust your meter needle to -10VU using the R44 "tracking adjust" trimmer(reflecting the 10db of reduction).
Now, mute your source signal(or short pad 22 to ground), and adjust the needle back up to 0VU using the "0 Set"(R71) trimmer.
Now un-mute your source signal again(or un-short pad 22), and readjust R44 trimmer so the meter needle again shows the 10db of gain reduction(-10VU).
Mute the source signal(or short the 22 pad), and again use the "0 Set"(R71) trimmer to adjust the meter needle back to 0VU.
You should see a slight bit of change(for the better) after each adjustment cycle.
So, repeat this back and forth adjustment procedure until the meter finally holds it's adjustments...
i.e., the meter needle will eventually hold at -10VU when you have the source signal present, and then go back to 0VU when you mute the source signal(or short pad 22 to ground).
Getting to this point usually requires many repetitions of that adjustment cycle.
Is any of this relevant to your troubles then? I'm getting tired of typing.
--Brian
R44 in
GRmode(20:1)
--Brian
