Echo North
Those values are actually good. All of your side chain numbers look great.
About unit gain that is not true. At 12 and 12 o'clock you will get a huge boost. Also keep in mind the input pot curve on the Bourns T-Pads is a little different that the originals so it will seem hotter.
Typically when we use the the input is around 9 o'clock and the output near 12 o'clock.
Noise is still an issue however. Kinda stumped.
Mike
Mike
