Echo North
JingleDjango said:Aha! Yeah! Jeez. That's totally it. I'm surprised it even worked for that long.
Ya that will do er'. Glad you found it!
JingleDjango said:What a careless error.I hope you've marked up your shipping costs enough to make this worth your time!
bdunard said:Just finished my second Rev D and I have run into problems with calibration.
I set the 1kHz sine to .775 VAC on the input but when I move it over to the output I can't get the level much over 1.1 VAC with the output fully CW. I have a REV D that is working so I checked the wiring against it and all looks well. I also went through and checked my resistors and those too look right. The unit powers up fine. Any ideas where I should start my search?
bdunard said:Should these voltages be checked with .0775 VAC at the input?
useme2305 said:bdunard said:Should these voltages be checked with .0775 VAC at the input?
0.775 VAC
JingleDjango said:useme2305 said:bdunard said:Should these voltages be checked with .0775 VAC at the input?
0.775 VAC
At the bottom of the schematic there is red text reading:
REVISION D WITH TYPICAL VOLTAGES ADDED
TEST CONDITIONS:
FULLY CALIBRATED UNIT, NO INPUT, GR MODE, LEFT ON FOR 1/2 HR
Hairball Audio said:Figure out where you're not getting the gain. In bypass you basically have a 40dB mic pre.
Start with the input and output at 12 o'clock, attack in OFF position, 20:1. Set you Qbias so you get pad 18 closest to 0VDC. Should be fully CCW. Inject you 0.775 VAC 1K signal into the input and again adjust it till you 0.775 VAC across input 2 and 3.
Again follow the schematic.
Set your DMM to AC and reference the 0V/CT on the main PCB power supply.
1. What is your AC @ the input transformer + on the in side? (should be smaller)
2. What is your AC @ the input transformer + on the out side? (should be smaller)
3. What is your AC @ the main PCB input marked "+" where the transformer comes in? (should be very small like 0.085 VAC)
bdunard said:I don't show any VAC between pad 18 and ground no matter where I turn the qbias. Reading was 0 VAC.
hymentoptera said:bdunard said:I don't show any VAC between pad 18 and ground no matter where I turn the qbias. Reading was 0 VAC.
Multimeter should be set to volts DC when measuring DC at Pad 18.
bdunard said:Thanks for pointing that out...my own careless error.
After metering pad 18 I got it down to 0 VDC but I had to turn the qbias CW which seems to go against what Mike was saying. If I have it full CCW I have about 1.119 VDC.
I know this is probably a stupid question but I'll ask anyway. I'm not understanding the three test points (1,2,3) and where they are located on the PCB that Mike is asking me to test?
I'm not sure what inside and outside mean...I'm sure this is a silly error on my part but I'm not getting it.
I've tested the input AC transformer outputs coming into the board and I have 29 VAC coming into the PCB on both sides.
I don't see any labels on the other transformer that suggest "+" or inside and outside...this probably what's throwing me off.
