edanderson
edanderson said:during the GR tracking adjust process, r44 is the trimmer that you use to get the meter to read -10db in GR mode. so yes, in answer to your question, r44 will change the amount of GAIN REDUCTION shown.
does that not directly answer your question? i can't say for certain why it isn't working for you... but again, r44 is the tracking adjust trimmer and should let you move the needle to indicate -10db gain reduction.
you can try replacing the GR FET Q11, or the two transistors that make up the meter circuit Q12 and Q13. i would suggest checking all the resistor values around those transistors and of course your wiring, but it sounds like you've done that already. it is possible for extra solder flux around the FET to cause a problem, but usually that is only over time as it absorbs moisture. still, if you haven't cleaned the flux away, that would be a good precaution.
the ratio doesn't matter that much; it is possible to do all the steps on any ratio setting, using 20:1 just makes it easier. i don't think that is your problem.
ed
