college101
If your using a 2k trimmer, its only a few turns to move the needle...I forget what I actually measured but it was close to 2K...
I would venture a geuss and say that something is shorting out your trimmer...maybee solder bridge on the pads between wider and ground....
I agree, you can use a voltmeter to set the reduction level, but the point your missing about the third calibration step, is you have to be able to get the 76 meter to accurately show that change in level...you can adjust all day long, if the needle doesnt show what your doing to the signal, you dont have any idea of the actual compression being applied...
