[Build] CAPI BT50, 500 Series EQ (a la 550), Official Support Thread
@jsteiger good news !!!! now it's working .... before the trip I was resoldering some joins...now I'm back and it's working...
Bad news, I have 1 2503 Litz that's not good, all the 4 coils work good 8 ohms , but then I connects the coils like
Red with white and measure black and yellow and in a good trainee I have like 19 ohms, but in the bad one I have like 9 ohms...If you have a best way to check it, let me know how and I will test it.
Cheers !!!!
Cheers !!!!
I would check each lead to all other leads. Make sure none are connected that shouldn't be. The only readings should be from the start to finish of a winding.
Hey all,
I think I got a bad switch on my HF I get no continuity on the last deck (furthest form the faceplate) in any position, all the other decks work as expected. So my HF has no boost or cut, the MF and LF still work. Is there any way to fix the switch? Is a replacement even in the realm of possibility?
Please send an email thru the store and we'll get it sorted.
