[Build] CAPI BT50, 500 Series EQ (a la 550), Official Support Thread
We need to know where the signal stops. To find this use a signal generator to send a +4dBu 400Hz signal to your EQ. If you don’t have a dedicated signal generator, send the 400 Hz signal from your computer (about -14 dBFS). Record the AC voltage at each test point, then post the results here.
If you haven’t cleaned the bottom of your board thoroughly, do that first.
Recleaned the bottom of the board, and double checked for any solder bridges.
Sent a tone generator to the EQ (400 hz, -14 dBFS), EQ bypassed. The output is very low, just above the noise floor.
Test Point Results:
TP1: 0.0 V
TP2: 0.1 V
TP3: 0.1 V
TP4: 0.1 V
TP5: 0.1 V
TP6: 7.0 V
TP7: 27.6 V
TP8: 22.5 V
TP9: 3.2 V
TP10: 1.1 V
TP11: 1.4 V
TP12: 1.7 V
Test Point Results:
TP1: 0.0 V
TP2: 0.1 V
TP3: 0.1 V
TP4: 0.1 V
TP5: 0.1 V
TP6: 7.0 V
TP7: 27.6 V
TP8: 22.5 V
TP9: 3.2 V
TP10: 1.1 V
TP11: 1.4 V
TP12: 1.7 V
Are those voltages AC? They look WAY off.
Here’s an example of voltages from a working unit that someone posted earlier:
TP1: 0.311V
TP2: 0.311V
TP3: 0.311V
TP4: 0.306V
TP5: 0.306V
TP6: 0.304V
TP7: 0.303V
TP8: 0.299V
TP9: 0.459V
TP10: 0.300V
TP11: 0.298V
TP12: 0.300V
This is pretty typical. You should at least have 0.3ish VAC at TP1.
TP1: 0.311V
TP2: 0.311V
TP3: 0.311V
TP4: 0.306V
TP5: 0.306V
TP6: 0.304V
TP7: 0.303V
TP8: 0.299V
TP9: 0.459V
TP10: 0.300V
TP11: 0.298V
TP12: 0.300V
Yes, AC voltage. I thought it was way off as well, so I remeasured ( I had the leads reversed). Still rather low.
TP1: 0.1 V
TP2: 0.1 V
TP3: 0.1 V
TP4: 0.1 V
TP5: 0.1 V
TP6: 0.0 V
TP7: 0.0 V
TP8: 0.0 V
TP9: 0.0 V
TP10: 0.0 V
TP11: 0.0 V
TP12: 0.0 V
edit:
I checked the DC voltage at the opamp -V and +V sockets. I measured -14.6 and 14.3 respectively. I resoldered the pins and got -15.2 and 14.8.
TP1 is immediately after the input amp so if you're low there (which you are) its either the way the signal is being applied to the module or the input amp A1.
The BT50 has a historically unbalanced input. What device is feeding the sine wave to the module? Maybe it doesn't like being unbalanced with the negative side going to ground?
I'm using the Cranborne 500R8. There is another in this thread where someone was using the Cranborne 500ADAT. I tried using the Konsole 6 with the MIDAS Legend 6 as well, no luck. Trying unbalanced cables next.
I was more wondering about the preceding device not the rack. Unbalancing the output of some converters can be interesting. A device with an output transformer won't care.
Hi capi gurus,
I’ve got a Bt50 that produces a 5k tone at all times even in bypass. It seems to modulate the freq when I change the LF selection or filters. And goes up to around 10k. I have a twin bt50 that doesn’t do this.
Swapped 1731 opamps no change.
Does anyone have a suggestion how to fix this it sounds fine everything works but this constant tone is making it unusable.
Thank you for your reply
Hi capi gurus,
That is new one. Its has to be a build error of some sort. I'd very carefully compare the good build to the bad build. Might also be a solder bridge somewhere on the build.
The Cranborne 500R8 in this case is the converter AND the rack. Curious if anyone has gotten the 500R8 to work with this EQ.
I have already told bababuoy in a dm that I have built the BT50 and have installed it in my Cranborne 500R8 successfully, fully functioning. Just mentioning it here in the event someone else is also curious about this situation.
I have two in a Cranborne audio 500r8 as well, they work perfectly. Building two more now 🤓
Hi guys. @jsteiger . I've made 10 BT50 Litz....I have some trouble with one. I have a loss of 4 db. The EQ works well, but with 4 db loss. No shortcut . Even if you swipe the jumper for +6 works but with the 4 db loss.
Testing tone 1Khz near -14db. running tone from laptop. Eq out. (not engaged)
For that level of input All TP's are near 0,37v AC, only TP 9 is 0,52v.
In a working fine unit those values are the same for that input level.
With Eq IN (engaged) and gain full in the 3 bands, the TP's go higher in value cause the gain add in each band.
But the TP 2 stay the same value as the eq wasn't.'t engaged like 0,37v.
Could this indicates a problem?
could any of the transistor go bad?
thanks in advance
cheers
Pedro
