benqbasic
Hi All,
I have an Antelope Audio Orion Studio rev 2017 that I've recently taken out of storage. I'm experiencing a gain balance issue with the main stereo output. The right output has 8dB less gain than the left. It doesn't seem to be a software or digital problem since the output discrepancy fluctuates with volume adjustments. As I increase the output, the imbalance grows. I can see the output voltage is lower on the faulty channel.
Unfortunately, this unit is out of warranty, and I'd like to attempt to fix it myself first. Although I'm not very experienced with SMD, I want to pinpoint the issue and only replace the faulty components if possible. The main output utilizes a BB PCM1792. Each channel has two OP1662 opamps. Based on the datasheet, I assume it is just the V/I to filter circuit, this is followed by some transistors (balanced output?) into a relay to select A/B output.
Any assistance would be greatly appreciated. What should I be looking for. Sending the unit back to Antelope would be a costly endeavor as I'm located in New Zealand.
Thanks in advance!
Thanks in advance!
