kante1603 said:Rob,
Wait until someone can confirm your mains wiring please.Must be done first,sorry.
After that we should "separate" the mains stuff from the rest of the psu meaning lifting the primaries of the transformer to get the rest of the circuit safe.
It might be a faulty mains switch or the voltage selector.
No fuses blown indicates that no high current was there after the mains fuse,so that is kind of a good sign,given the fuses have all the right values and reaction time.
What you can do meanwhile is double check the right fuses being in the right places.Also while on it double check all the parts on board visually,especially the electrolytic capacitors because what confuses me a bit is that "pop" sound.Is any of them becoming round on top or is one even open etc.,does anything smell burnt...........
Udo
kante1603 said:Pardon me,I swapped names because I'm in contact with other members trying to help at the same time,mea culpa,hahahaha.......
Transformer checking can be done by looking for their dc resistance at least.
You have to disconnect both sides (all wires) from the trafo and measure the primaries and secondaries with your dmm set to ohms.
Each pair will give you a reading although the values will be quite low,but under no circumstances should you get a zero ohms reading.
Same measuring must be done between secondaries and primaries (guess you have a trafo with two primaries,right-otherwise the voltage selector would not work).
Again there shouldn't be any connection between these pairs.
For the switches just ohm them out,either they have a good contact (reading superclose to zero ohms) or are in open condition (superhigh resitance,dmm will go out of range).
If there's anything in between then you must replace this part.
Sorry for swapping names again,
Udo.
Yes,the windings themselves,then interconnections between the different windings.Toure14 said:Just to clarify Udo, in order to check the Transformer, remove all transformer leads and connections, and check for resistance between secondary windings and primary windings?
[silent:arts] said:most common failures:
- not properly isolated regulators
- mixed up LM370 and TL783 (make sure the TL783 is IC1 / 48V)
Only one TL783 and four LM370 inside,the TL783 must sit in the 48v part of the circuit.Toure14 said:mines are islotaed but i need to check to see i they are in the right place
jsteiger said:You can measure resistance between the metal tab of the TL783 and the heatsink side. This should not be a low value. No need for the power to be on for this, just checking for a direct short.
