gyraf said:
Can anyone confirm that using the LM350T in a negative-voltage configuration like this is really kosher?
Sum-up of the incident.
Dual VPR & 51x Floor Box PSU, powering 51x rack containing only two Lola's. All newly built, tested to be ok.
On patching at patchbay (which may or may not have a bit of voltage potential, non-grounded computer PSU) - the -16V regulation on PSU blew, taking -16V fuse with it.
Another - also new and fresh - 51x rack + Floor Box PSU was tried, Lola's moved over in it. Worked nicely until changing patch, which killed it instantly - again the -16V regulator.
Which made me wonder if the Floor Box PSU is adequately protected from reverse voltages, as the used LM350's are VERY hard to kill with anything else.
We changed the -16V LM350, and mounted reverse-voltage protection diodes:
2pcs 1N4007 - soldered at underside of PCB, at the power-output screw terminals. You could probably also simply screw them into the terminals together with the output power cables:
- One goes from -16V to 0V (arrow/stripe pointing towards ground/0V)
- The other goes from 0V to +16V (arrow/stripe pointing towards +16V)
The reverse protection diodes work by preventing the -16V from going above +0.6V and preventing the +16V from going below -0.6V
At re-installation in the exact same setup that killed the psu's earlier - and working hard to provoke the error - we could not recreate the fault.
In conclusion - it may be a good idea to include the reverse protection diodes.
Jakob E.
PS: Very nice project btw: I never looked closer at this before, amazed about the high quality standards..
