[silent:arts]
For 115V they are wired in parallel, for 230V in series.
The ACV at the secondary are not referenced to ground. Make sure your DMM is set to ACV and then probe between the color pairs. Red to red, orange to orange etc.rachansky said:Starting from the outboard in pairs 19.13V(red wire) 12.57V(yellow wire) -4.24V (green) 36.83V (white) and 2.843 (orange)
Thanks very much for your time with this Jeff. I have already gone over the BOM to the best of my ability to check the placements.
OK so you have the 51x PSU. The 48V leads are white not black.rachansky said:Oh mother....
OB to IB again 29.2, 19.5, 19.5, 55.5, 29.2
Excellent! Sometimes its hard to imagine all the ways something can be screwed up! Glad you found it. Now get some sleep.rachansky said:I am a bit of an insomniac so I started disassembling the psu and found that the O.G. builder did indeed install the ICs incorrectly. He had IC1 and IC4 mixed up. I only wish my eyes were good enough to see that earlier! Pain in the butt for removals and reinstall but its alive!
This likely explains why I was having issues with phantom power on my 1073lb as well. Anyway loaded up the rack and the voltages move less than 0.1V with 11 units installed. Too tired now to try the problem modules but I am looking forward to the final tests tomorrow.
Thanks for the support Jeff Steiger!
It seems as though you have the 51x Floor Box? That will run one full rack on +/-16V and one full rack on +/-24V. So adding another VPR only rack would NOT be advised. You could change the transformer to the dual VPR version. It would also require changing 4 resistors on the PCB.rachansky said:Ok all my units are working as they should. Now please clarify for me as I have read what feels like contradictory notes in this thread.
Am I able to add another vpr rack with this psu?
Yeah man. I saw your email this AM but have been too busy to reply.rachansky said:One more thing monsieur Steiger! I see that you have the rack kits back in stock, I am unable to add a faceplate for the dual vpr box to my order unfortunately. Do you ever make exceptions to this? I would like to keep it 100% on the level. I'll even ship back my DIY one if you liken
