As discussed via email, if you are using our filtered racks with a Floor Box PSU, you need to change the 160mA fast blow to a slow blow. The inrush current required to charge the rack's filter caps is enough to trip the fast blow fuse.curranm said:I have set the voltages for all the IC's in the PUS on my bench before I installed any modules or plugged in the racks. I have blown the phantom power fuse twice now in my PSU. I have two of the VPR racks with 6 modules in each one. 6 of the element preamps, and 6 of the VP25's. the fuse popped on 1st power up with modules in it, I replaced it thinking I had shorted the 48v with my probe when I was testing voltages on the card slots for voltages on 1st power up. I replaced the 48v fuse and everything has been fine for a week. I added the 2nd rack and moved the modules around and POOF, I popped the 48v fuse again. Am i goofing up and a power on sequence or should I not have the Phantom power engaged on the modules OR is there a limit to the number of modules I should phantom power at one time? my understanding is that these should NOT have this issue. all my voltages are set per the build docs, and everything has been working fine for the last week, I just added the 2nd rack to the mix.
[silent:arts] said:Check your Voltage before the fuse.
Check your Voltage before the 48V regulator.
Check your 48V AC voltage at the PSU transformer.
[silent:arts] said:The caps should be empty and safe now![]()
After such a long time?New Soul Rebel said:It isn't! It still has around 20 volts!
[silent:arts] said:However, 20V won‘t kill you.
New Soul Rebel said:Volker, do you mind if I ask you a question. I have pulled the PCB on this PSU so that I can get easier access for testing.
But the 48v regulator still has charge going to it, even when the board is removed and disconnected from the toroidal. Around 23 volts dc. How do I safely discharge it, so that I can work on it as the reg looks damaged and needs replacing i think
I have the same voltage at
Matt
[silent:arts] said:5 x 20 mm
No. Correct is:tyskstil said:From the bottom: Bolt, washer, plate, washer, nut, toroid, nut. Correct?
Fantastic - that makes much more sense. Thanks![silent:arts] said:No. Correct is:
Bolt, washer, plate, transformer, washer, nut.
