Its just some simple math and depends on your DAW reference level. For example, if your system is -18dBFS = 0dB, then just offset my -30dBu numbers by -18 so you would use -48dBFS. For the +7dBu level you would use -11dBFS and of course for 0dBu it would be...you guessed it -18dBFS.geardude said:BUMP![]()
Lot's of folks here trying to find a way to calibrate ITB, myself included! Want to order the new version as there's no THD calibration, but I don't want to bite off more than I can chew. Having watched the hairball compressor calibration video's and understanding the the basic principles behind analog dbu & digital dbfs and it's relativity to you're interface/AD daw etc... it's all a bit much. Care to chime in DIY Gods?
