Yes. Sorry but I cheat and use an Audio Precision so its easy for me.
I'm not Jeff, but it seems you've ordered the kit with the Litz wire transformer (instead of the standard EA2623). Check your order to confirm, then follow the table on the datasheet found via a link on the product page for, or here: http://www.capi-gear.com/catalog/images/gallery/2623/2623-1-L-specs.pdfLud said:Hi Jeff, i'm on the end with the making and my transfo has no blue green and brown wires. Instead it has a grey a pink and a purple. Could you enlighten me?
Cheers.
Lud.
jsteiger said:Have you tested the audio path and other test points per the docs? I would not worry about trying it with a bad opamp installed.
jsteiger said:Lud, maybe you are misunderstanding the tests. TP1 is just after the balanced receiver stage. If you have signal applied to the input and this TP has no reading, the input stage is not passing audio. If the input stage is not passing audio, there will not be any audio getting to the rest of the circuit. Maybe you are measuring here for DC? If you are using a DMM, you can only measure audio in ACV mode.
The all discrete will need 3 discrete opamp kits with it.Golgoth said:What is the difference between All Discrete, +1 and +2 for the FC526?
