Post a quick pic of that part of the build.420troll said:R71 and R73 are good
R42 Not sure where to ground the O scope so using the ground point and no signal at R42
jsteiger said:Post a quick pic of that part of the build.
jsteiger said:Did you check R42 closest to C17 or the other end?
Yes. You should measure the windings for DCR. That would be from pin-5 to 8, pin-1 to 3 and pin-2 to 4.420troll said:Waiting for a reply. Should i pull the transformer out and test?
jsteiger said:Yes. You should measure the windings for DCR. That would be from pin-5 to 8, pin-1 to 3 and pin-2 to 4.
420troll said:I put the transformer back in and tested everything again.
The signal good at R71 & R73.
No signal at R42 and ground.
jsteiger said:The 2622 DCR looks correct.
Maybe you have the 2 transistors swapped immediately after the 2622?
jsteiger said:Check DCV at the top of R36 and then R37. Check on the ends closest to R40.
jsteiger said:Sorry I missed this.
Q1, BC560C:
C -15.43
B -.588
E .046
Q2, BC550C:
C 15.14
B 0
E -.589
I do not publish the schematic for this project. I never have. I am honestly lost as to where you are and what your problems are. I got the impression from your last post that something dramatically changed when you put it all back together. I do not have all of the test point data memorized so it would be helpful if you could post what you have vs what it should be.420troll said:Whats the word O keeper of the schematics? I have been waiting a couple of days to hear back what to do next.
Out of about 60 DIY kits from effects to synths including the ARP 2600 clone, samplers, drum machines this is the most painful support, at this rate I guess i will have a 500$(Canadian dollars the cost for me )distortion unit. I have never had a project I could not get going even faulty circuit designs i have help provide insight into what could be going wrong why do you make this so hard for me? Some hi res pictures and a schematic I am guessing I could tell you where the problem is.
