Hi guys, new to the forum. I've built one successful VP28, but I am hitting a pretty big hiccup when i'm testing my newly built 526-Litz.
I am reading 10.02 V DC at TP 9. I am reading 2.503 V DC at MTR point #11.
I've sent a 1k test tone thru my DAW and i'm getting 243.3 mV AC into the unit, as well as 243.3 mV AC on the output of the unit while bypassed.
I have turned RV2 clockwise probably 20-30 turns clockwise.
input gain, output gain, attack, and release are all fully CW, and 20:1 Ratio is confirmed selected.
Once I turn it to active, GR OFF, and SC HPF disengaged, I am getting the following readings, with my DMM set to AC voltage, one lead on the ground lug, and the other lead to the following:
TP 1: 56.6 mV AC
TP 2: 1.14 V AC
TP 3: 9.17 V AC
At the output, i'm reading 18.29 V AC
With the unit active, and GR on, i'm getting the following readings:
TP 1: 56.6 mV AC
TP 2: 0.951 V AC
TP 3: 7.0 V AC
At the output, i'm reading 15.25 V AC
With the unit active, GR on, and SC HPF In, i'm getting the following readings:
TP 1: 56.6 mV AC
TP 2: 0.928 V AC
TP 3: 7.46 V AC
At the output, i'm reading 14.87V AC
I have confirmed that none of my capacitors , diodes, or transistors are in backwards (I triple checked but who knows). And I did as Chunger suggested, I put all the resistors in before soldering anything that way everything is copasetic. I also spent about 4 hours yesterday double checking every single resistor with color code method, I checked every single capacitor, transistor, switch, IC.. I literally went through the build with a fine tooth comb. I cannot see where this went wrong.
I’ve also used 3 OP amps and get the same test values +/- a couple of mV. I’ve also tried a couple of different slots in my Lindell 506 power supply with very similar results too. At this point the only thing I can think of is maybe a bad solder joint. I have confirmed there are no solder bridges as far as I can tell (and I’ve stared at the thing at least 4 hours lol). Any help would be awesome, thanks in advance.
Kahn
Oh and by the way this is an awesome community that I'm proud to be a part of, and Jeff has been extremely helpful thus far.
![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
